Today I retreived the U-623-1 axle adapters, Wd-630-1 nose wheel fork, U-713C left and right nose wheel fairing brackets, U-603-3 nose gear leg and all the attaching hardware. I edge finished the U-713C left and right nose wheel fairing brackets and final dimension drilled the U-603-3 nose gear leg for the fork attachment bolt hole.
Axle adapters, nose wheel fork, wheel fairing brackets and attaching hardware
U-713C-L & -R Nose wheel fairing brackets
Nose gear leg fork attachment bolt hole final dimension drilled
